1999 Ford F150 is losing oil
1999 FORD F-150
SOUSADAD
2 days ago, my 1999 Ford F-150 4.2L V6 started losing oil on the driver's side of the block somewhere. I haven't had a chance to look closely, but is it possibly the OSU, if the oil is coming from that area? It is coming from somewhere above the oil pan seam for sure. The engine was running good when last turned off. The next morning, oil was discovered on the driveway under that side. Looking for a starting point.
Jan 9, 2006 at 3:35 AM
CHOFFMAN41
  • 11 POSTS
I don't remember where the sending unit is on a 4.2, but I have seen them leak oil where the plastic is crimped to the metal so that sounds like a good place to start........
Jan 10, 2006 at 3:11 PM
DUDE
  • 50 POSTS
double check its not the oil pan gasket , had it happen once
Jan 10, 2006 at 4:43 PM
SOUSADAD
For information's sake, I found something surprising. My oil filter had a crack in it. First time for me with this problem. What seems weird is that the filter had been on there for 2000 miles but just start leaking. Thanks for the advice.
Jan 11, 2006 at 4:21 AM
