Trying to track down the causes for my overheating problem. I've been working on this problem for approx 4 days now. Once consistant problems seems to be with air pockets in my cooling system. What could be causes leading to getting air in my cooling system? Last year, I had a heater core replaced in my F-150XLF. The mechanic indicated the other day that when doing the work he did not install a reducing hose, since it was an additional cost item. Could this be a contributing factor to air in my cooling line? The problem is that air can block the flow of coolant to the engine, thus causing a overheating situation. Is there a way that I can bleed the system to remove the air in the line?
Thursday, October 28th, 2010 AT 8:10 AM
