1999 Ford F-150 In-Tank Fuel Pump Fix
SIRALLEN1
Can I replace in tank fuel pump with in line high pressure fuel pump without having to remove the tank
Jan 2, 2006 at 8:23 PM
GODBEAR839
  • 77 POSTS
no you have to drain it then drop the tank then you can fix it and remember gas is explosive no smoking or sparks.
Jan 10, 2006 at 1:09 AM
Suggested Repair
Drain the fuel tank, drop the tank, and repair or replace the in-tank fuel pump. An inline high-pressure pump cannot be substituted without removing the tank. Keep all ignition sources away because gasoline is explosive.
Conversation Summary
The owner of a 1999 vehicle asked whether the in-tank fuel pump could be replaced with an inline high-pressure pump without removing the tank. The expert said no and advised draining and dropping the tank before repairing it, with a warning that gasoline is explosive and smoking or sparks must be avoided.
