TRUCK RAN FINE LAST NIGHT TRIED TO START IT TODAY AND IT WAS NOT FIRING OVER
Thursday, March 25th, 2010 AT 2:32 PM
MECHANIC
Was the check engine light on? Also, are you able to check for spark and fuel to the engine?
SPONSORED LINKS
Thursday, March 25th, 2010 AT 10:03 PM
PATRICK064
MEMBER
The check engine light is on for P0401 and P0455 which is EGR large leak and insufficient flow. I have replaced the hosing to the EGR system the EGR valve the throttle control and one other valve on the fire wall. I erased the errors and the engine started. I believe that the GPFE needs to be replaced to end this problem.
