1998 Ford F-150 Spark Plug Change
DEEWILL68
  • 1998 FORD F-150
  • V8
  • 187,356 MILES
What tools are needed to change sparkplugs, can't afford to go to a specialist every time I need a service or repair problem, too exspensive, so I need to know every tool that is required to change the plugs, I have some now but not sure on how to get the plugs out that are far in the back on both sides.
Tuesday, August 25th, 2009 AT 11:07 AM
MJR346
  • 132 POSTS
7mm socket, 8mm socket, 10 mm socket 1/4 ratchet with extension.
5/8 spark plug socket, extensions, ratchet
plug gapper
recommend Torque wrench and dielectric grease
It's a 2.5-3 hour tuneup for a pro if I remember the book time. The easiest way on passenger side is to remove that whole fuse block. Drivers side you fight it.
That's why mechanics charge so much to change the plugs on one.
Tuesday, August 25th, 2009 AT 7:57 PM
