HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Symptoms
Low Power
SPONSORED LINKS
1998 Ford F-150 NO POWER
DEBBIECLIFF
MEMBER
1998 FORD F-150
V8
4WD
AUTOMATIC
175,000 MILES
FUEL PUMP WENT OUT AFTER R&R IT HAD A BAD MISS, DID A TUNE UP, NOW IT ATART'S OK AND RUN'S OK BUT HAS NO POWER, IT WON'T PULL IT'SELF HARDLY.
updated 2/25/09
fuel pressure is 40lb solid
Tuesday, February 24th, 2009 AT 1:27 PM
BLACKOP555
MECHANIC
Get a fuel pressure reading and get back to me.
Has fuel filter ever been changed?
SPONSORED LINKS
Tuesday, February 24th, 2009 AT 9:56 PM
BLACKOP555
MECHANIC
How long has the vehicle sat? If a vehicle sits too long the vehicle could be having issues with bad gas fouling up the plugs causing a running issue.
Even plugging up a fuel filter.
Also the transmission could be slipping very very badly
Thursday, February 26th, 2009 AT 10:10 PM
Please
login
or
register
to post a reply.
Related Engine Low Power Content
Losing Power, Stalling And Popping On Straightaways...
I Bought His Truck, 1998 Ford F-150 4.2l Supercab, Two Years Ago. We've Only Used It For Short Trips For The Last Year Until Yesterday. I...
Asked by
hopefarm
1998
FORD F-150
VIDEO
Fix an Engine with Low Power!
Instructional repair video
GUIDE
Symptoms of Low Engine Power
The power your car's engine is producing is important. When you step on the gas you need your car to accelerate, mainly to keep you out of trouble when getting onto the...
Engine Hesitates And Sluggish Acceleration
A Recent Problem Is A Lack Of Power At Acceleration. It Hesitates And "bucks" From Start And From A Roll. I Have To Shift Down To...
Asked by
MrDetroit
11 IMAGES
2001
FORD F-150
Most Of The Time When You Are Trying To Accelerate And...
History: 5.4l Fx4. Have Replaced Cam Phasers, O2 Sensors, Plugs, Injectors, And Throttle Body. (Some Of These Were Done For Other...
Asked by
rjwalch
2005
FORD F-150
1992 Ford F150 Lack Of Power/clutch Pedal Too Easy To...
I Am Experiencing A Total Lack Of Power. Gears Do Not Seem To Be Catching. Could Adding Sae 80 Fluid Be A Easier Repair Than Going Through...
Asked by
millie6
1992
FORD F-150
1999 Ford F150 Loss Of Power
I Have A 99 F-150, 4.6l V8 With 216,000 Miles On It. The Truck Reads No Codes When Hooked Up To The Computer And No Check Engine Light Is...
Asked by
sullivanjo
1999
FORD F-150
VIEW MORE
SPONSORED LINKS
Catalytic Converter Replacement
Online car repair manuals
