1998 Ford F150 Hydraulic clutch resevoir
1998 FORD F-150
15,400 MILES • V8 • 4WD • MANUAL
SARGE727
I just purchased a 99 F-150 and was checking fluid levels. The clutch res. has a long diapragm which is hollow inside. This hollow part was filled with fluid. Isn't the fluid supposed to go on outside of diapragm otherwise I don't see how any of the fluid could make it to the cylinder. Thanks, Sarge
Apr 14, 2009 at 11:58 AM
BMRFIXIT
  • 19,053 POSTS
Very possible some one add fluid in the wrong area just clean it out very good and wipe it clean and if fluid get in it again replace it.
Apr 14, 2009 at 12:09 PM
SARGE727
Thanks a bunch, I appreciate the advice
Apr 14, 2009 at 12:25 PM
