Hi there,
You need only purchase the faulty item and replace it, if the slave is leaking just replace that and re bleed system, but if you wish you can replace all hydraulic components at the same time, very few people would replace the hose if it is not damaged, The cylinders are not repairable and should be renewed if leaking.
Mark (mhpautos)
SPONSORED LINKS
Tuesday, January 15th, 2008 AT 9:56 AM
