1998 Ford F150 hello
THEMARTINEZ
Electrical problem
1998 Ford F150 V8 Four Wheel Drive Automatic
my trucks driver seat is not working. is electrical but when i try to pull the seat back it doesnt work. but when i push it to the front it does work. it also works when i push it up and down but doesnt work to the back wat is the problem
Jul 9, 2010 at 6:29 AM
INTERNETMECHANIC
  • 700 POSTS
I usually take the connector loose from forward/reverse motor, use jumper wires for voltage and ground, use inline fuse, because it is a reversing motor, you switch the jumpers placement depending which direction you want the seat to move. If the seat moves forward and back correctly, I suspect the seat control switch. If the seat still doesn't work correctly, I suspect the forward/reverse motor.
Jul 9, 2010 at 7:19 AM
