1998 Ford F-150 gauges don't work
MONG55
  • 1998 FORD F-150
Computer problem
1998 Ford F150 V8 Two Wheel Drive Automatic
Hi. I own a 1998 F150 XLT with 52,000 miles. The gauges (speedometer, tachometer, oil pressure, fuel, temperature and charging gauge) does not work. The rest in the instrument cluster works (warning lights). The truck runs great otherwise. Everyone points to the GEM Module. Any comment?
Thanks.
Wednesday, June 16th, 2010 AT 3:44 PM
  • 109,885 POSTS
That could be the problem. Many of them were damaged due to a leak from the windshield that would allow water to drip down onto them. It is located behind the fuse panel. Check to see if there is any evidence of water damage?
Wednesday, June 16th, 2010 AT 10:12 PM
