HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Symptoms
Coolant In Oil
1998 Ford F-150
MIKA101
MEMBER
1998 FORD F-150
V8
2WD
AUTOMATIC
150,000 MILES
Found water in oil
Saturday, December 19th, 2009 AT 10:00 PM
MECHANIC
Do you start and go and don't give the engine a chance to come up to normal temperature if so could be just condensation-moisture turns in to water in the crankcase-also check the PCV valve
SPONSORED LINKS
Sunday, December 20th, 2009 AT 6:11 AM
Please
login
or
register
to post a reply.
Related Engine Coolant In Oil Content
Coolant In The Oil?
I Have Condensation In My Oil Cap It Is A Milky Color, What Is Wrong?
Asked by
byronwade
2004
FORD F-150
VIDEO
Can You Fix a Head Gasket with a Sealer?
Instructional repair video
GUIDE
Coolant Mixing With Engine Oil
Coolant mixing with engine oil is a sign of a serious problem, often caused by a blown head gasket, or a failed engine oil cooler. When these components fail, they allow...
Fuel Mileage Very Poor?
My Engine Has Less Than 60000 Miles On It. It's Out Of A Wrecked 01 Model. I'm Only Getting Around 15 Mpg On The Highway. Check...
Asked by
JesseShaffer
7 IMAGES
1998
FORD F-150
1998 Ford F150 Truck Won['t Start
My Truck Won't Start- Battery And All Cables Have Been Replaced- Starter Checked Out Fine- Three Times) It Used To Click When Trying To...
Asked by
jocole33
1998
FORD F-150
1998 Ford F150 Engine Stalls At Idle When Damp
During Idle Speed Engine Is Very Prone To Stall Out When Conditions Are Damp (snow Rain). -after Stalling Out, Engine Does Not Start Back...
Asked by
b00sh00
1998
FORD F-150
1998 Ford F150 Engine Knock
Now That The Weather Is Getting Cold I Noticed That When I Start My Truck I'm Getting A Knocking Sound From The Engine. It Sounds To Loud To...
Asked by
mcox0112
1998
FORD F-150
VIEW MORE
SPONSORED LINKS
Cylinder Head Gasket Blown Symptoms
How to Build a Ford 302 Small Block - Part 6:
Online car repair manuals
