1997 Ford F-150 Wont run or start
AZRENAGADE
  • 1997 FORD F-150
  • V8
  • 213,000 MILES
I Was driving the truck & it just died, Like it ran out of gas. It was just filled up that morning & drove 15 miles. Had it towed home & now it turns over but dosnt start. Also drains the battery dead overnight. Any ideas?
Monday, July 5th, 2010 AT 9:57 AM
  • 109,896 POSTS
Are you getting spark and fuel to the engine? Also, have you checked for an electrical draw on the battery?
Monday, July 5th, 2010 AT 7:08 PM
AZRENAGADE
I Have spark, No fuel, fuel pump relay is engageing, jumped fuel pump & it isnt working. Dont know proper way to test for battery draw but I do have parks at the battery with everything off
Tuesday, July 6th, 2010 AT 10:03 AM
  • 109,896 POSTS
If the relay is working, then you either have a bad wire to the pump, a bad connection at the pump, or the pump is bad.
As far as the draw, it is easy to check. Here are directions.
http://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
Let me know what you find.
Tuesday, July 6th, 2010 AT 3:48 PM
AZRENAGADE
Thanks for all your help joe. I found a clifford emobioizer under the knee panel in the passenger department. It must of shorted out becouse I removed it & now everythin is working great.
Wednesday, July 7th, 2010 AT 5:14 PM
  • 109,896 POSTS
Hay, I'm glad it's fixed. Let us know if you have other questions in the future, and thanks for using 2carpros. Com.
Thursday, July 8th, 2010 AT 12:07 AM
