1997 Ford F150 power windows and interior lights
1997 FORD F-150
155,000 MILES • V8 • 2WD • AUTOMATIC
LABELI
When I open my door and the interior light come on I know I have power windows. When the interior lights click off before I shut the door, I know the power windows won't be working. Some how these are on the same circuit. I can be driving and I can hear a "click" and then the windows will work. The wipers also seem to be tied into this but not all the time. If I don't have wipers, I can turn off the engine and then just turn on the ignition but don't start the engine and the wipers will work. This is driving me nuts as I have replaced relays thinking one might be shorting or hanging up but it hasn't helped.
Jan 23, 2010 at 7:49 AM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Havee you tried swapping out the Battery Saver Relay? It amy be that, but it loks like those things also get power via the G.E.M module. have seen a bunch of those have issues.The C.T.M Central Timer Module also controls those functions
Jan 25, 2010 at 2:09 PM
LABELI
I think it may be the GEM as my window weather stripping wasn't seated in the windshield right. I used a mallet and tapped it down in there and siliconed it. I sure didn't spot any moisture around the GEM but hit it with a hair dryer(blower) and the darn thing seems to be working for now! Will definitely keep those other two you mentioned in mind. Thanks again!
Jan 25, 2010 at 7:21 PM
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Good find. I should have asked about water leaks, those trucks tend to crack windshields on the drivers side bottom and the water goes right in the GEM
Jan 26, 2010 at 7:31 AM
