My heating / air conditioning blend door opens and closes randomly. I replaced the potentiometer and nothing changed. I took it to my mechanic and he said the new potentiometer was bad because his ohm meter readings didn't change when he operated it. I tested it myself and found the readings between the first and 3rd terminals to move smoothly between.6 and 4.9 on the 20K ohm scale. I have no idea whether this is a good reading. I would like to know if the potentiometer sounds like the problem and also what operates the door - could the problem could be caused by a vacuum leak?
SPONSORED LINKS
Tuesday, September 8th, 2009 AT 2:38 PM
DOCFIXIT
MECHANIC
Hi
Actuator motor moves blend door the Pot. Varies voltage. Check term. 2 to 3 operate check ohms. Does it change?
Let me know
Thanks for donate
Tuesday, September 8th, 2009 AT 3:08 PM
JOE BOYLE
MEMBER
On the 20K OHM scale
Terminals 1-2 range is 4.96 to.6
Terminals 1-3 range is unchanged 4.85 4.85
Terminals 2-3 range is.67 to 4.79
SPONSORED LINKS
Tuesday, September 8th, 2009 AT 4:36 PM
DOCFIXIT
MECHANIC
O.K. Pots good so accuator motor maybe faulty. Check motor operation center dash on top HVAC box
