HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Climate Control
Heater
SPONSORED LINKS
1997 Ford F-150 Heater stuck on hot
LORIG
MEMBER
1997 FORD F-150
Heater problem
1997 Ford F150 V8 Four Wheel Drive Automatic 115k miles
I have a '97 F150 115K, after the winter, my heater has been stuck on heat, and I'm unable to use my a/c. Any suggestions?
Saturday, June 28th, 2008 AT 5:19 PM
MERLIN2021
MECHANIC
The temperature blend door actuator could be broken, is this auto temp control or manual a/c and heat?
SPONSORED LINKS
Saturday, June 28th, 2008 AT 5:24 PM
LORIG
MEMBER
1 POST
My truck is a manuel temp change
Monday, July 21st, 2008 AT 8:05 PM
MERLIN2021
MECHANIC
First thing to check is if it needs a recharge, and if the cooling fan comes on when you turn on th A/C
Tuesday, July 22nd, 2008 AT 2:40 AM
Please
login
or
register
to post a reply.
Related Heater Content
1997 Ford F-150 Heater And Air Conditioner Problems
My Air Conditioner Is Blowing Out Hot Air And My Heater Is Blowing Out Cool Air. What Could Be The Problem And Could The Same Part Be The...
Asked by
bieber
1997
FORD F-150
GUIDE
Heater
Once the engine has been started and has run long enough to warm up the hot coolant is transferred into the heater core which is located inside the passenger compartment via...
Ranger Heater Always On!
Hi, I Have A 2.3 L, Ford Ranger With 150,000 Miles That Runs Wonderful! But, For The Past Year Or Longer My Heater Is Always On. With...
Asked by
RobertSanchez
FORD F-150
Heater
I Have 1999 Ford Taurus. 115000 Miles. When Turning On The Heat The Heater Blows Hot Air For A Few Seconds But Then Cools Off Right Away....
Asked by
donnie0328
1 ANSWER
FORD F-150
1997 Ford F-150 A/c
When I Turn My Ac On It Blows Out The Vents. But When I Give It Gas And Going Down The Road It Starts Blowing Out The Defrost Till I Let Off...
Asked by
chiknwing
1 ANSWER
1997
FORD F-150
Blower Will Switch From The Vents To The Defrost Vents
While Ac Is Running, When I Accelerate The Blower Will Switch From The Vents To The Defrost Vents, Then Back Again When I Let Off The...
Asked by
Dale Owen
1 ANSWER
2001
FORD F-150
VIEW MORE
SPONSORED LINKS
Heater Not Working
Heater Not Working
Heater Hose Replacement
Online car repair manuals
