1997 Ford F-150 Heater and Air conditioner problems
BIEBER
  • 1997 FORD F-150
  • V8
  • 160,000 MILES
My air conditioner is blowing out hot air and my heater is blowing out cool air. What could be the problem and could the same part be the cause of both problems?
Tuesday, September 28th, 2010 AT 9:15 AM
WRENCHTECH
  • 20,761 POSTS
By "hot", do you mean ambient temp or heated air?
By "cold", do you mean air conditioned air or ambient temp?
Tuesday, September 28th, 2010 AT 9:18 AM
BIEBER
Both ambient temperatures.
Tuesday, September 28th, 2010 AT 9:20 AM
WRENCHTECH
  • 20,761 POSTS
OK, so you just have temp control stuck in one spot.
The heat in that vehicle is controlled by a blend door that regulates heated air flow. It is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
Tuesday, September 28th, 2010 AT 9:22 AM
BIEBER
Is it easy to get to by myself or would an ASE mechanic have to do it. Where is the actuator located at? How much would one cost if it is damaged or inoperable.
Tuesday, September 28th, 2010 AT 9:28 AM
WRENCHTECH
  • 20,761 POSTS
Unless you have a mechanical background, you're going to have trouble with this. It's up under the dash and it depends exactly what the problem is as to the cost. If it's a bad actuator, probably a couple hundred bucks but if the door itself is messed up, the entire dash has to be removed and then the entire HVAC housing has to be removed and disassembled. It can get real expensive.
Tuesday, September 28th, 2010 AT 9:33 AM
