Leaky rear axel seal on the pass side
JSE121975
  • 1997 FORD F-150
I have a ford f-150 truck with a leaky rear axel seal on the pass side and want to know how to remove the s-lip in the rear differential so I can remove the spider gears and then the c-clip and axel shaft
Friday, July 23rd, 2010 AT 6:26 PM
OBXAUTOMEDIC
  • 3,711 POSTS
All you should have to do is remove the Pinoin Shaft Locking Bolt, slide it out then push the Axle Shaft in to remove the C-Clip suggest using a magnet to remove c-clip. Then pull out axle.
https://www.2carpros.com/forum/automotive_pictures/188069_97f150rearaxle_1.jpg
Press CTRL + to zoom in
Monday, May 17th, 2021 AT 1:18 PM
