1995 Ford F-150 Runs ruff no power
MT2103
  • 1995 FORD F-150
  • V8
  • 4WD
  • 210 MILES
I got a 95 f-150 v8 efi new plugs, wires, distributor, battery, and starter. I starts fine but runs ruff like there is not enough power to make the truck go. Once I get past 10-15 mph it goes away till I slow back below 15. Any ideas?I was thinking egr valve, or maybe a air sensor idk dont want to waste anymore money
Friday, August 13th, 2010 AT 12:28 PM
BILLYMAC
  • 2,204 POSTS
Yes the egr valve is a great possibility. When it is idling rough tap on base of egr valve if eng idles up egr carboned up remove and clean all carbon off
check for vac leaks
Friday, August 13th, 2010 AT 4:31 PM
