1998 Ford F150 EGR Valve
175,000 MILES • V8 • 2WD • AUTOMATIC
ROBRANDS
Truck will not idle on a cold start without giving it gas. Once the engine warms a little it idles rough and eventually smooths as it approaches operating temperature. Also, when driving, it wont shift into drive 3. It acts like it is running out of gas. The tank is full and fuel pressure is 40 lbs. I have a single code on OBD II scanner P1401 exhaust gas recirculation insufficient. Are the above symptons consistant with an EGR valve malfunction?
Dec 5, 2007 at 7:26 AM
BLACKOP555
  • 10,386 POSTS
yes those symptoms are very well present with a EGR valve failure. it can easily be cleaned wihtout being replaced!
anything else i may assist you with?
Dec 5, 2007 at 11:51 AM
