1995 Ford F-150 Will not even try to turn over.
WARRENMATT
  • 1995 FORD F-150
  • V8
  • 14,500 MILES
My buddy gave me this truck. It won't do anything. When I turn the key over the lights, air conditioning, headlights turn on. But when I go to turn it over it won't do anything, no noise even. I bought a new starter, and battery. But it didnt do anything. Any tips, or advice?
Matthew
Monday, October 11th, 2010 AT 8:35 AM
  • 109,755 POSTS
Have you checked to see if there is power to the starter? Is the starter relay good? Have you checked the ignition switch?
Monday, October 11th, 2010 AT 8:51 AM
WRENCHTECH
  • 20,761 POSTS
The problem could be anywhere is the starter circuit like ignition switch, neutral switch, relays, fuses, etc.
Check at the solenoid next to the battery that the small wire is on the "S" terminal. Try using a jumper wire to apply power to that terminal. If it cranks, that means the starter battery and solenoid are good and the problem is elsewhere in the circuit.
Monday, October 11th, 2010 AT 8:52 AM
