1994 Ford F150 possible transmission slip
1994 FORD F-150
208,000 MILES • V8 • 2WD • AUTOMATIC
BRANDONMC11
my 1994 eddie bauer f-150 is acting up, when i was driving home from work the other day the check engine light came on, never been on before, when this happened i lost all power, truck was still running but i just wasnt going anywhere. the check engine light went out and the transmission picked up for a min and then the light came on and the truck lost power again, it did this all the way home, is it possible that it is slipping or maybe just a sensor went out? i fiqure it may be a sensor since it will run fine for a while but then the light comes on, any help is appreciated.
Jun 19, 2010 at 10:41 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Have you had had the computer scanned? It could be a trans control module (TCM).
Jun 19, 2010 at 10:56 PM
W1987G
I had the same problem with mine, only on long trips right? Check your exhaust 02 sensor, mine was busted and I haven't seen that problem since. Thing cost me like $35 and I haven't had a problem since.
Jun 22, 2010 at 10:42 PM
