1994 Ford F-150 oilpressure
TIM58
  • 1994 FORD F-150
  • V8
  • 6,768 MILES
No oil pressure on oil pressure gauage and an oil leak from rear majn oil seal would it be ok to drive
Wednesday, June 9th, 2010 AT 1:26 AM
Check the oil pressure with a mechanical gauge if okay replace the oil pressure switch abnormal could mean oil and engine bearings-
Do you have an engine knocking noises-if not its your wish to continue to drive it but best be checking the oil level at all times
Wednesday, June 9th, 2010 AT 2:14 AM
