1994 Ford F150 exhaust manifold
1994 FORD F-150
135,800 MILES • V8 • 4WD • AUTOMATIC
FITZ2
I need to replace the exhaust manifold on the passenger side of my F150, 1994, 5.8 engine, part time 4X4, long box. How do I do it?
Sep 11, 2010 at 1:22 PM
  • 110,244 POSTS
Remove the Y pipe so the exhayst system is no longer attached to the exhaust manifold. After that, it is just a matter of unbolting the manifold, properly cleaning old gasket material from both the head and the manifold, and replacing the part. I do recommend a couple things. First, make sure to disconnect the battery before any work begins. Next, spray all bolts involved with a good penetrating oil, let them sit over night, and spray them again about a half hour before you start the work.
Sep 11, 2010 at 1:33 PM
