I have a 1994 F-150 w/ 242k miles on it. I recently changed out the water pump and the harmonic balance. My truck
ran like a champ for a few days but then out of no-where I was idling at a redlight and my truck started to bump, its the only way to describe it and the longer I run it the worse the bump gets. Also, about the same time the bump started my truck started to loose horsepower. I have the 5.0 V8 in it and normally im doing 40 if I barely touch the gas. But now I have to mash the gas to get to 60, you can hear my engine
rev. And its trying to work but it just has no power.
Any help would be greatly appreciated.
Just as a heads up here's a list of the things that have been changed in the past two years starting most recent to least:
Water pump
Harmonic balance
Plugs, wires, distributor
Starter
Brakes
Rear differential fluid
Battery
SPONSORED LINKS
Thursday, February 18th, 2010 AT 4:57 PM
