HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Climate Control
Heater
Not Working
SPONSORED LINKS
1994 Ford F-150
JERALD MORRIS
MEMBER
1994 FORD F-150
6 CYL
2WD
AUTOMATIC
143,000 MILES
Engine runs hot but does not overheat when weather is warm, heater does not get hot when weather is cold, I have replaced thermostat.
Can you help
Wednesday, December 2nd, 2009 AT 1:02 PM
MECHANIC
I need you to check something. With the engine hot, running, and the heater on high, do both heater core hoses get hot.
SPONSORED LINKS
Friday, December 4th, 2009 AT 7:22 AM
JERALD MORRIS
MEMBER
1 POST
One hose was warm but not hot and the other one was cool to the touch.
Friday, December 4th, 2009 AT 12:22 PM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
1994 Ford F150 Very Little Heat
3 Thermastates And Still Very Little Heat Temp Gauge Never Gose Past The (n) In Normal On The Gauge Heater Doors Open And Close Fine Ther...
Asked by
spider6
1994
FORD F-150
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
Why My Heater Isn't Working?
I Have A 2002 Ford F150 4x4, 5.4 Triton Eng. I Have Change Thermostat But Still No Heat. If I Turn Fan And Heat Off It Will Build Pressure...
Asked by
noles
23 IMAGES
2002
FORD F-150
Heater Blew Nothing But Cold Air That Evening
I Replaced The Stat In My '97 Ford F150 - 4.6l. The Heater Worked Perfectly The Next Morning. It Blew Nothing But Cold Air That Evening...
Asked by
Mikie
1 ANSWER
FORD F-150
2003 Ford F150 Thermostate Is A Half And No Heat....
Replaced Thermostate, Motor Still Will Run At Half On Gauge But No Heat At All, Then The Thermostate Will Run 3/4 To Nearly Completely Hot...
Asked by
johnandy22
2003
FORD F-150
2003 Ford F150 Ac/heat Not Working
I Noticed My Ac Was Not Working And Took It To Have It Serviced. They Did A Routine Ac Service And Added One Can Of R13 But It Still Did...
Asked by
Eaustin
2003
FORD F-150
VIEW MORE
SPONSORED LINKS
Heater Not Working
How to Replace Damper Door Switch
Blend Door Actuator Replacement
Online car repair manuals
