Clutch pedal went to the floor?
PC1MACMAN
  • 1993 FORD F-150
  • 6 CYL
  • MANUAL
  • 172,000 MILES
Tryed Starting my truck this morning it was stalling out a few times then the cluch pedel went to the floor. Pulled it back up with my foot and the truck started and now the cluch woks fine?
Thursday, November 19th, 2009 AT 2:15 PM
KHLOW2008
  • 41,814 POSTS
Hi PC1MACMAN,
Thank you for the donation and sorry for the delay in replying.
The symptoms indicates the clutch master cylinder is failing and leeaking internally. Check the clutch fluid level and check for leaks at the slave cylinder and master cylinder ( check the pedal push rod end for leakages from the master cylinder).
Perform this test.
Start vehicle.
Depress clutch and shift into 1st gear.
Hold the clutch and wait for 10 seconds.
If while waiting, the vehicle seems to be engaging as if the clutch is being released, turn engine off to prevent it from moving forward. This indicates the clutch hydraulic system pressure is leaking and would need to be repaired.
Friday, November 20th, 2009 AT 2:49 PM
