Fuel leeks. Comes out the fill hole. Like its biulding preshur and pushies it out the fill hole. The front tank hole
Monday, January 11th, 2010 AT 4:31 PM
MECHANIC
Is it burping out of the filler tube when filling it or is it leaking from the filler tube?
SPONSORED LINKS
Monday, January 11th, 2010 AT 10:49 PM
ZACK BLACKWOOD
MEMBER
Its leaking out of the top of the filler tube where the cap is. It leaks only after driving, almost like pressure builds up and after driving it leaks out of the top of tube. If I remove cap it would pour out. Its like pressure builds.
Tuesday, January 12th, 2010 AT 12:28 PM
MECHANIC
That is interesting. There is a one way vent, I believe on the rear of the tank, that my be bad. Check that to see if it is blocked.
Tuesday, January 12th, 2010 AT 1:27 PM
ZACK BLACKWOOD
MEMBER
How would I check that?
Tuesday, January 12th, 2010 AT 1:31 PM
MECHANIC
It will only allow air to go in one direction.
SPONSORED LINKS
Tuesday, January 12th, 2010 AT 1:35 PM
ZACK BLACKWOOD
MEMBER
Do I have to drop the tank to fix this?
Tuesday, January 12th, 2010 AT 2:38 PM
MECHANIC
You shouldn't have to. Check with a flashlight to see if you can see anything that looks like a cap at the end of a hose.
