1989 Ford F-150 Fuel tank switch inoperative
JONAS.CALSBEEK
  • 1989 FORD F-150
  • 6 CYL
  • MANUAL
  • 155,000 MILES
When trying to switch between fuel tanks, I notice that nothing happens when I flip the switch back and forth. Is this a solenoid issue?
Thursday, May 29th, 2008 AT 6:05 PM
BLACKOP555
  • 10,371 POSTS
Do you notice the fuel guage change any?
Probably a faulty fuse or bad switch.
Thursday, May 29th, 2008 AT 6:42 PM
JONAS.CALSBEEK
  • 5 POSTS
Well the gauge is pegged out past the FULL mark and I'm troubleshooting that as well, probably need to just switch out the gauge. I opened the fuel door to listen for the fuel pump in either tanks but couldn't distinguish what was going on. I will probably try and swap out the switch as all of the fuses are good and appropriate size.
Thursday, May 29th, 2008 AT 8:37 PM
BLACKOP555
  • 10,371 POSTS
Sounds like a good idea.
Also make sure the wiring harness is in good shape to both tanks and to the switch.
Friday, May 30th, 2008 AT 9:12 AM
JONAS.CALSBEEK
  • 5 POSTS
The wiring harnesses that you are referring to are located just before the fuel pumps, correct? I had a hard time locating the wiring without getting the truck on a lift. Thanks for the help.
Saturday, May 31st, 2008 AT 12:49 PM
BLACKOP555
  • 10,371 POSTS
Yes those are the harnesses.
Saturday, May 31st, 2008 AT 1:31 PM
