1990 Ford F-150 Speedometer
BIRD36459
  • 1990 FORD F-150
1990 Ford F150 6 cyl Four Wheel Drive Manual
The speedometer on my truck stopped working a while back and for a while it would jump when I would slow down or push the clutch. Now it doesnt work at all. I have replaced the cable and the gear and after each it would work for about a day then stop working completely. Can you please help me figure out whats going on with it?
Wednesday, February 24th, 2010 AT 4:31 PM
  • 109,885 POSTS
Have you rechecked your work and parts you replaced? I ask because if the cable and the gears are both good, then chances are the speedo itself is bad.
Friday, February 26th, 2010 AT 12:54 PM
BIRD36459
No I changed the speedometer so its new. Could it be the gear in the transmision?
Thursday, March 4th, 2010 AT 2:04 PM
  • 109,885 POSTS
I thought you replaced the gear in the trans? If you haven't, yes it could be bad. I believe it is a nylon gear.
Friday, March 5th, 2010 AT 6:27 AM
