In '86 R-12 was still in use
We converted it to R-134
The fittings for "12" are different than for "134"
If yours is already set up for "134" you are good!
If not, you need to hit Autozone or Advance Auto for a Adapter Fitting for "134"For the Low side only (the employees) can show you LOW SIDE!.....high side is for more advanced testing that maybe you are not "skilled" for.......Low is for filling the system---Kinda EZ to doDO NOT TRY TO FILL THE HIGH SIDE!!!!!!!
At one time, maybe you still have it, The A/C CAPACITY is on your truck SOMEWHERE!.....Under the hood, door, glove box door, owners manual, and Repair Manuals .........Parts Store guys may have it in their books.
Regardless---you are only going to fill, TILL FULL, according to a GAUGE.....not to the decal....especially if you still have gas in it!
Here are things you need:
Gauge on a hose separate from fill bottle (video below will show one)reuseable!
A fill hose (for cans)----Reusable!, unlike the all in one cans
You might need "AN OIL CHARGE"---ask at store, tell them your WHOLE HISTORY and SITUATION to determine whether to get oil or not
DO NOT PUT IN TOO MUCH OIL!!!!!......parts guy question....eyes on.......hands on
3 Cans of "134" should be plenty (always is for me, even if the system was empty).........unless you have a van or a rig with a rear Evaporator (2 A/C systems)
Remember, if you are going to remove a can...live and charging......Turn off the valve, remove hose from truck..............Install gauge for Pressure Test/ Check..........Remove gauge hose.........reinstall the Freon can.........open its valve to continue to fill................DO NOT OVER FILL!
Regardless what the gauge says........Your Low line will "SWEAT"......Don't put so much freon in, that the line "SWEATBACK" forms on the compressor inlet on the compressor
SWEATBACK means the gas is turning back into liquid (as it should) But you do not want liquid in the compressor----DAMAGE CAN OCCUR!!!..........So watch the compressor fitting.........You do not want condensation forming there.....on the hose is fine!
Here's your start---several parts to it, should play on thru to them...give it some time.
http://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Read "Votes" and Remember me in "FEEDBACK"
I'm still here to help
Just reply
The Medic
Wednesday, September 15th, 2010 AT 9:01 PM
