1989 Ford F-150 Battery Not Charging
LILWOGG08
i have a ford f150 i just replaced the alternator and it still isnt keeping my battery charged i was wondering what it could be can some one take a look at this and please help me out thank you
Dec 28, 2006 at 3:40 AM
DB554
  • 35 POSTS
Try changing your batt. term. wires sometimes they get corroeded from the inside and will not carry a charge.
Dec 28, 2006 at 7:51 AM
DB554
  • 35 POSTS
It could also be you have a bad batt.
Dec 28, 2006 at 7:52 AM
FIGUE04
  • 8 POSTS
You can take your battery to your local auto parts store and have it checked. Most of the battery wires do get corroded and need to be replace as well as the terminals. Average cost for the replacments of wires and terminals $15.00 Dlls.
Dec 30, 2006 at 11:02 PM
TAURUSWHEEL
  • 718 POSTS
Spend a couple of bucks, get one of the little battery hydrometers, I think they're called, and test each cell if possible to do so...
Dec 31, 2006 at 8:49 AM
Suggested Repair
Have the battery tested at an auto parts store or with a hydrometer on each cell. Also inspect and replace corroded battery cables and terminals, which can fail internally and prevent charging.
Conversation Summary
The owner of a 1989 Ford F-150 replaced the alternator, but the battery still will not stay charged. Replies suggest a bad battery or corroded battery cables and terminals that cannot carry a charge, and recommend store testing, a hydrometer cell check, and replacing the wires and terminals.
