problems with my alternator keeping my battery charged?
CURTIS
I am having problems with my alternator keeping my battery charged. I have had the alternator checked at serval auto part stores and they all say it's good. I have changed the voltage regulator, Changed starter and starter solenoid. Also i just bought the battery in December brand new. :cry:
Feb 16, 2006 at 1:18 PM
GODBEAR839
  • 77 POSTS
has the battery been tested? might be your problem also could be bad wires from the terminal posts I have seen a couple of vehicles with corroded wiring causing this kind of issue.
Feb 17, 2006 at 1:43 AM
PEPPERMRJ
  • 1,158 POSTS
The only other thing I can add is that there could be a drain on the battery. A glove box light on, etc. If the battery tests out ok, take a look at night and maybe pull some fuses.
Good hunting and let us know. :)
Feb 17, 2006 at 4:41 AM
Discussion summary
The poster reports an alternator that won’t keep the battery charged on an unspecified vehicle. They say multiple auto‑parts stores tested the alternator and reported it good; the poster has replaced the voltage regulator, starter and starter solenoid, and installed a new battery in December. Despite those parts changes and the tests, the charging problem persists according to the poster.
Reported outcome: The poster did not report a resolution; no successful repair or confirmed fix was reported in the thread.
Read the original discussion
