HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Exterior Light
Reverse Light
1989 Ford F-150
KIP_723272001
MEMBER
1989 FORD F-150
Electrical problem
1989 Ford F150 V8 Two Wheel Drive Automatic
Back Up Light SwitchFor your 1989 Ford Truck F150 1/2 ton P/U 2WD 5.8L FI Windsor 8cyl
Saturday, September 11th, 2010 AT 11:03 PM
MECHANIC
The back-up light switch is combined with the neutral safety switch-see below
Sunday, September 12th, 2010 AT 7:55 AM
Please
login
or
register
to post a reply.
Related Reverse Light Content
Tail Lights Wont Turn Off
This Problem Affects Only The Red Part Of The Following Lights: The Tail Lights And The Outside Cab Light For The Truck Bed. First Of All...
Asked by
GJ26
10 IMAGES
2008
FORD F-150
VIDEO
Reverse Light Bulb Replacement
Instructional repair video
GUIDE
When replacing a reverse light bulb check all directional and headlight bulbs as well, use high quality bulb to avoid premature failure.
1998 Ford F150 Daytime Running Lite
My Daytime Running Lites Will Not Shut Off
Asked by
grumpabeens
1 ANSWER
1998
FORD F-150
Turn Signal Light Added In Mirror?
My 2012 F150 Side Mirrors Does Not Have Turn Signal Lights. Can These Be Added In The Blank Spaces
Asked by
sandcay
4 IMAGES
2012
FORD F-150
Multifunction Switch Wire Diagram?
Where Can I Find A Wire Diagram That Lets Me Know Where Exactly The Wires Need To Go On A Multifunction Switch On The Steering Wheel. I...
Asked by
e777rodriguez
2 IMAGES
1999
FORD F-150
1998 Ford F150 Head Lights Wond Come On
Head Lights Do Not Turn On All Other Lights Work But Not The Head Lights
Asked by
obdyo01
1998
FORD F-150
VIEW MORE
How to Use a Test Light
Have a Dim Headlight? - Try Replacing This!
