Hello !
Your truck has autolamps? (Day on lights and automatic night lights)
Fog lamps?
Its not working on low and High beams?
Be sure that you checked all the fuses1
There`s three fuses for the headlights one 30 Amps on the power distribution center (under the hood with the main fuses and relays) and one 20 for the low beam and one 30 amp for the high beam.
The wiring its a little bit complicated because ford uses a daytime running lights controller and a multifunction switch.
You have to have some electrical knowledge to read the schematics that`s why we are going to start with the basic stuff.
Friday, January 4th, 2008 AT 8:54 PM
