I own a 89 ford f150 some times it works in 4 high and 2 wheel and some times it ackts like it kicks out of gear but it pulls hard in 4 low no prob what could be going on
Tuesday, August 24th, 2010 AT 4:59 PM
MECHANIC
Doeske it seem like the transfer case kicks out of gear?
SPONSORED LINKS
Tuesday, August 24th, 2010 AT 8:27 PM
BILLYBOY1974
MEMBER
Yes it seems to engage and then kick out
Wednesday, August 25th, 2010 AT 5:05 PM
MECHANIC
Have you checked the linkage to make sure it is tight and properly adjusted? Also, is this an electric shift 4wd?
Wednesday, August 25th, 2010 AT 9:02 PM
BILLYBOY1974
MEMBER
No I have not and no it is manual 4 wheel how hard is it to adjust linkage?
Saturday, August 28th, 2010 AT 4:39 PM
MECHANIC
It is easy to adjust. First, check to make sure it is attached and moving the lever on the transfer case.
