HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Ignition
Spark Plug
Replace/Remove
1988 Ford F-150 yellow spark to the spark plug instead of bl
SHADETREE2
MEMBER
1988 FORD F-150
6 CYL
2WD
AUTOMATIC
15,900 MILES
Replaced coil, ign module, distributor, cap rotor, wires, ign switch.
Tuesday, June 2nd, 2009 AT 10:08 PM
BLACKOP555
MECHANIC
Check to make sure you are getting 12V in with key on and a -12v pulse when cranking at the ignition coil connector.
1 voltage less can significantly cut out the final output of the coil.
Whats the spark like directly from coil?
SPONSORED LINKS
Tuesday, June 23rd, 2009 AT 11:08 AM
Please
login
or
register
to post a reply.
Related Spark Plug Replace/Remove Content
Spark Plug Replacement
Instructions And Steps To Replace Spark Plugs In A 2002 F150 4.6l
Asked by
Richard_Reffuse
2 IMAGES
2002
FORD F-150
VIDEO
Spark Plug Replacement Ford
Instructional repair video
GUIDE
A spark plug is a vital part of the engine's ignition system and is responsible for starting the combustion process. As a part of an engine tune up, spark plugs should ...
1999 Ford F150 Replaced Spark Plugs, Now Has Rough...
I Replaced The Fuel Filter, Spark Plugs And 4 Of The Coil Boots. After The Work Was Done I Started The Truck And Everything Sounded Fine. I...
Asked by
bcw1973
1 ANSWER
1999
FORD F-150
2005 Ford F150 Spark Plug Removal
I Have A 2005 F150 That Im Changing Spark Plugs On. I Broke Them All Off And Bought The Tool To Get The Rest Of Them Out. I Got The Front...
Asked by
thohensee
2005
FORD F-150
Spark Plug Change On 2007 F-150
I Was Wondering If There Is Anything Special I Should Do Or Be Aware Of Before I Change The Spark Plugs On My 2007 Ford F-150 (5.4l/v8)/
Asked by
JohnnyGQ
2007
FORD F-150
2004 Ford F150 Spark Plugs Change
I Have Horror Stories About Changing Spark Plugs In The 5.4 Triton, That They Break Off In The Head. Some People Have Told Me It Is The...
Asked by
nbruce
2004
FORD F-150
VIEW MORE
SPONSORED LINKS
Spark Plug Replacement Honda
Spark Plug Toyota Tundra V8 4.7L 2000-2006
Spark Plug Replacement Honda Element
Online car repair manuals
