On the fender right next to the battery, follow the positive cable to the starter solenoid, the smaller wires are fusible links, test them with a test light, replace the ones that dont light the light before and after the FUSE bump. If all test OK check/ replace the battery cables.
SPONSORED LINKS
Tuesday, May 5th, 2009 AT 3:06 PM
