1987 Ford F-150 starter
GARY12345
  • 1987 FORD F-150
Electrical problem
1987 Ford F150 6 cyl Two Wheel Drive Automatic
my starter will keep starting when key is in off position
Wednesday, September 15th, 2010 AT 12:19 PM
WRENCHTECH
  • 20,761 POSTS
As this is happening go to the solenoid next to the battery and pull off the small wire at the "S" terminal. If the starter stops, then the problem is in the starter circuit in the truck somewhere and will have to be troubleshooted from a wiring diagram. If it does not stop, that solenoid id bad.
Wednesday, September 15th, 2010 AT 12:49 PM
