1987 Ford F150 idle bouncing
87,500 MILES • 6 CYL • 2WD • AUTOMATIC
DON33
  • 11 POSTS
My daughters ford pick up idle bounces when in park and when you first put in gear but only does it for a minute then is fine runs great when you drive it ive change the egr valve throttle position sensor idle air controller cleaned the throttle body new fuel filter fuel pump cap rotor spark plugs and the other basics she just turned 16 and got her license today ide like to get it running right for her i did put on code reader and came up fuel pressure curcuit but dont know where to start
Jul 20, 2010 at 3:13 PM
  • 110,244 POSTS
Have you checked the fuel pump pressure?
Jul 20, 2010 at 3:17 PM
DON33
  • 11 POSTS
no have not done that doesnt it have two it dual tanks idle bounces on both if so what one thanks
Jul 20, 2010 at 3:24 PM
  • 110,244 POSTS
It could if the fuel pressure regulator is bad. There is only one that regulates both. It is on the fuel rail. There is a vacuum hose going to it. Remove the vacuum hose and see if there is any evidence of fuel getting into it.
Let me know what you find or if you need directions for checking it.
Jul 20, 2010 at 5:01 PM
DON33
  • 11 POSTS
chaecked the fuel pressure today the pressure is 50 it says its supposed to be between 33-39 is 50 bad
Jul 21, 2010 at 3:57 PM
  • 110,244 POSTS
Yes, that is too high. I would say the regulator is bad.
Jul 21, 2010 at 5:47 PM
DON33
  • 11 POSTS
changed the regulator today still doing it now im really stumped
Jul 23, 2010 at 1:13 PM
DON33
  • 11 POSTS
hey just found out my buddy that did the pressure test said the pressure is supposed to be between 50-59 mine was at 43, also found out that the egr that is new is not getting any vaccum what could that be
Jul 23, 2010 at 1:45 PM
  • 110,244 POSTS
The fuel pressure is one problem. As far as the EGR, check the vacuum hose to make sure it isn't plugged, damaged, or disconnected.
Jul 23, 2010 at 6:14 PM
DON33
  • 11 POSTS
i checked that also took to vacuum line off that goes from the egr to whatever is sitting below the egr that part seemed clogged with something i took it apart and blew threw it couldnt get ari out of one of two ports but dont know what it is it has two vacuum line connection on bottom and a filter on top with an electrical connection off the side
Jul 24, 2010 at 3:22 AM
JOSHUA028
  • 13 POSTS
What does the vacuum regulator loom like. I am having a vacuum problem with my 2001 ford f150.
Jul 24, 2010 at 5:59 AM
DON33
  • 11 POSTS
i going back to the new tps i put in i took it over did code reader again and the tps keeps coming up is there something that leads back to that or am i just lost cause i confused sorry for jumping around so much
Jul 24, 2010 at 7:24 AM
  • 110,244 POSTS
Can you upload a picture of the part? I'm not sure what you are describing.
Jul 24, 2010 at 4:20 PM
