Just make sure you put back the wires correctly on the starter relay-if you get battery voltage on the S terminal in crank position and nothing coming out of the battery terminal going to the starter-Like Mr. Jack said replace it.
Let me ask you this do you have a starter relay or a solenoid on the starter-What I gave you is for the relay not for the solenoid on the starter
Tuesday, February 12th, 2008 AT 10:53 AM
