1986 Ford F150 switching engines
DIYSGUY
Engine Performance problem
1986 Ford F150 V8 Two Wheel Drive Manual 100+ miles
Purchased truck as a project. I am taking out a 351 (blown top end do to poor rebuilod) and replacing it with a 369. Are the motor mounts going to line up correctly and what are other issues that I may run into.
Mar 8, 2009 at 12:55 AM
MIKE H R
  • 3,094 POSTS
The motor mounts should be the same. With a engine swap you can get in touch with summit racing , they carry a line o motor mounts made by Moroso for engine swaps. There web site is summitracing.com Good luck with your project
Mar 8, 2009 at 3:04 AM
