1994 Ford F150 v8 swap
17,400 MILES • 6 CYL • 2WD • AUTOMATIC
CT97FD
Im looking to rebuild my truck from the ground up, it has the 4.9 v6. I want to put a 351 v8 in it. Is this possible? Can the frame haddle the swap, and are the motor mounts the same?
Jun 4, 2009 at 9:02 PM
BLACKOP555
  • 10,386 POSTS
the new engine should fit right in there. yes the frame will handle it. but will the rear end? depends on the year if it will match up. not all sensor will match up either.
Jun 23, 2009 at 4:00 AM
CT97FD
Thanks
Jun 24, 2009 at 10:45 PM
