1986 Ford F-150 Engine is flat when you start out
EJZINGA21
  • 1986 FORD F-150
  • V8
  • 4WD
  • MANUAL
  • 146,000 MILES
I have an 86' F150 with a 302 FI I have a hesitation and it backfires when I rev the engine it almost acts like a vacume hose isn't connected but I have traced every hose changed the egr valve/ sensor throttle position sensor Idle air control Valve/ MAP/ egr solonoids/ air temp sensors new wires and plugs, new rotor and distrabutor cap and tons of other things and I am totaly stumpped so please help me
Monday, April 21st, 2008 AT 6:21 PM
BLACKOP555
  • 10,371 POSTS
I would check exhaust back pressure, and ignition timing and along with a fuel pressure check and new fuel filter.
You should run a few half tanks with 1 bottle of seafoam per tank.
Monday, April 21st, 2008 AT 8:10 PM
