I have a 1984 ford f-150 with a 2 bbl motorcraft carb and my truck is running waaaaay lean can you tell me how to fix it?
Thursday, September 18th, 2008 AT 6:24 PM
MECHANIC
Check the fuel pressure, check the accelerator pump if its squirting fuel as you step the gas pedal or just pull the throttle back /try readjusting the air/fuel mixture screws and check ignition timing and look for vacuum leak
