1972 Ford F150 Carb./Fuel Problem
100,000 MILES • V8 • 2WD • AUTOMATIC
JD329
  • 16 POSTS
I have a 72 F100 that will not accelerate. When you hit the gas it revs up for a second then it completely shuts off. It will stay running if you pump the gas but it cuts off if you dont. It has a 302. This problem happened suddenly. The truck had been running fine.
May 25, 2008 at 7:57 AM
RED_RUSSIAN1
  • 5 POSTS
I would say that either the accelerator pump or fuel pump is bad, both of which are inexpensive and easy to replace.
Jun 7, 2008 at 6:30 AM
JD329
  • 16 POSTS
I ended up rebuilding the entire carb and that fixed the problem. Thanks.
Jun 14, 2008 at 6:30 AM
