2001 Ford Explorer Spark Plugs
XJETMECH
  • 12 POSTS
I have a 2001 Ford Explorer Sport. I need to change the spark plugs. Right side going to be a problem. What needs to be removed in order to do this.
Dec 22, 2006 at 8:43 AM
GARFIELD
  • 197 POSTS
Just for starters I am sure that the fuel injector rails will have to be removed to gain access to the coil packs and spark plugs. Once the fuel rails are removed the coil packs and plugs come out pretty easy.
Dec 23, 2006 at 11:50 PM
Suggested Repair
Remove the fuel injector rails to access the coil packs and spark plugs. After the rails are removed, the coil packs and plugs should come out fairly easily.
Conversation Summary
The owner of a 2001 Ford Explorer Sport needs to replace the spark plugs and expects the right side to be difficult to reach. The expert says the fuel injector rails must be removed to access the coil packs and spark plugs, after which they should come out fairly easily.
