1999 Ford Explorer No Overdrive
ANGELACALHOUN
My 1999 Ford Explorer was experiencing miss-firing of a spark plug and skipping. The spark plug and wires were replaced several times within a 1.5 year period. Just recently the problem became extreme and upon further investigation, the vacuum hose of the fuel line was found to have slipped off and was said to be throwing off the compression of the engine. More resently, the "Check Engine" light came on (again). A diagnostic check showed the same spark plug miss-firing. I replaced the spark plug. Two days later I had the fuel injector cleaned and later that evening the transmission suddenly refused to go into overdrive. The "O/D Off" light came on. The engine continues to run smoothly ever since that vacuum line was adjusted. The transmission has never given any trouble up until the "O/D Off" light came on. It operates perfectly in the first two gears and reverse, but it just won't get the third gear. The transmission fluid was slightly low and dark in color (burned). I topped the fluid off, but the problem persists. Does the vehicle sound as though it will need more than a transmission fluid change and servicing?
May 1, 2006 at 5:13 AM
LOSONE
  • 1,616 POSTS
You have a tranny problem. I don't know exactly what could be the probem but when the light flashes it is an internal problem. The vacuum hose was to the fuel pressure regulator--it made for a very rich engine.
May 1, 2006 at 7:15 AM
Suggested Repair
Have the transmission diagnosed for an internal fault. The O/D Off light indicates an internal problem, so a fluid change and service alone are unlikely to restore overdrive. Low, burned fluid supports further inspection. The earlier vacuum-hose issue was the fuel-pressure regulator hose causing a rich mixture and is separate from the transmission fault.
Conversation Summary
The owner of a 1999 Ford Explorer reported repeated spark-plug misfires. A slipped vacuum hose on the fuel-pressure regulator was corrected, and the engine then ran smoothly. After injector cleaning, the transmission would not enter overdrive and the O/D Off light came on, while lower gears and reverse still worked. The fluid was slightly low and dark. The expert said the light indicates an internal transmission problem and that the vacuum hose had caused a rich mixture.
