2000 Ford Explorer Rear Door Won't Unlock Fix
AADAM
I have a 2000 Ford Explorer with power locks and within the past few months the driver side passenger door lock has been hit or miss with unlocking. As of yesterday, the lock will not open at all- my problems: the door automatically locks when I drive away (so I can't just not lock it) and to try to fix the problem- the door is locked so I cannot open it to get to dissassemble the lock. Does anyone have a solution?
Apr 15, 2007 at 12:39 AM
TAURUSWHEEL
  • 718 POSTS
Keyless entry?? Digital keypad?? There is a procedure to cancel out the auto locking system when you shift thru reverse, it's in the owners manual.. it's possible that it may be the lock solenoid is faulty, the piece that controls the locking action
Apr 15, 2007 at 1:50 AM
MERLIN2021
  • 17,250 POSTS
You could always unlock it manually then pull the fuse? Then you can open the door to fix it.
Apr 15, 2007 at 1:57 AM
CRAIGFL
  • 89 POSTS
Are the doors "child proof" in the rear? If so, there may be some kind of safety lockout mechanism that's not working right.
Apr 16, 2007 at 7:27 AM
Suggested Repair
Use the owner's manual procedure to cancel auto-locking when shifting through reverse. Unlock the door manually, then pull the power-lock fuse so it can be opened for repair. Check the rear child-safety lock and the door lock solenoid, which may be faulty.
Conversation Summary
A 2000 Ford Explorer rear driver-side power door lock became intermittent and then would not unlock, while the doors auto-lock when driving. Experts suggested disabling auto-lock per the owner's manual, unlocking manually and pulling the fuse to access the door, and checking the child-safety lock and lock solenoid.
