driver rear door wont open
127,865 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
CARBUFF64
i have replaced the inside door handle twice and always check the child door lock, I have even switched the child lock in both directions and still the door wont open from the inside. I have lubed the linkage inside the door also.
Jun 23, 2016 at 4:47 AM
  • 110,251 POSTS
If the child safety lock isn't engaged, the only thing it can be is either a bent, disconnected, or broken linkage or the latch itself is faulty.
Jun 23, 2016 at 12:12 PM
