Please help! Its beensitting for 10 months
BROOKLYNCRUZ
  • 1992 FORD EXPLORER
Hello all,
first time here. I have a 92 ford explorer that's been sitting for almost a year. I'm just trying to get an idea of what it will need (besides a new battery) to be up and running. Not a car expert, obviously, so i'm just trying to get an idea of anything that might need to be replaced. What goes wrong with vehicles when they've been sitting for so long?
i'll appreciate any responses to my question. Thanks!
Friday, January 13th, 2006 AT 10:57 AM
DUDE
  • 50 POSTS
Not a whole lot other than battery and fresh gas
if it was sitting on grass check brake lines
Friday, January 13th, 2006 AT 2:41 PM
WANZER2
  • 11 POSTS
Check all your fluid levels, tire pressure, gas and battery may just need a recharge
Sunday, January 15th, 2006 AT 6:44 AM
KENNJOY
  • 15 POSTS
The things those idiots forgot to mention was that you may have rust in your radiator so buy a flush and fill kit and use it to clean your radiator
Monday, January 16th, 2006 AT 12:18 AM
TKLINCK
  • 8 POSTS
Was the car sitting on grass or cement? After doing all the other stuff mentioned, if it still doesn't start, check all your ground wires and all your relays/wire connectors. I had a car parked for about a year on grass, and it started up fine. A week later, it wouldn't fire. Turned out to be a corroded relay next to the fan.
Friday, January 20th, 2006 AT 8:33 AM
